Re: bt no conection
Posted: Mon 13. Jul 2015 22:47:32
thankyou soo much, got it to connect now to find out how to use it, went to stability stick input but cant change it off 6, but will look further. again thankyou
I see the first cable (red+orange) from BT modul is connected to SYS - corect, but second cable for power (red+brown) is connected to pin on Spirit ELE/PIT/AIL - IT IS BAD! You must connect these cable to power suply. If You can, then try disconnect cable from AUX and use these pin for BT modul. Or You can use spare pins on reciever where is power suply too.john1127 wrote:Here is how it is set up
