Re: Rescue forces helicopter towards the ground.
Posted: Wed 28. Jun 2017 11:04:56
Sorry, been to busy to reply in a while. But on Sunday I noticed that some of the servo wires exiting the gyro would touch the canopy. So I pulled the wires down and strapped them to the gyro by putting a wire strip around it. That did give a noticeable improvement, but by no means solved the problem.
I got in 20 flights that day, and every one of them started with level rescue and ended with the rescue being between 30 and 60 degree off.
I have setup my radio to call out the time every minute, and I have gotten into to habit of putting the heli in a hover and test the rescue every time that happens. Then stop trying new maneuvers if it is to crocked.
I realize this is not perfectly safe, but I go to a comfortable height and orientation where I'm pretty confident I will be able to manually recover it no matter what happens when I hit rescue.
The one time I tested it using the spectrum analyzer the aileron axis would sometimes get high enough to emit a warning when it was standing on the skids on my table spooled up to full speed without blades. But when I tilted it up to reduce the ground resonance it would drop down. The two other axis was very low.
Unfortunately the last flight on Sunday ended when a link popped off one of the aileron servos and I crashed. Luckily I got away with only minor damage, and I got it repaired yesterday. Before I fly it again I will try to do a vibration analysis again without blades to see what it looks like now.
I do not have another spirit to test. The helicopter have had one really nasty crash in addition to the one on Sunday. That crash was pretty much a re-kit and it demolished the microbeast that came with the kit. And although rescue always worked flawless on the beast I did not like the arcane setup with a single button and blinking lights. So hence I bought a spirit to replace it. I also replaced everything rotating except the torque tube and the motor. So it was running very smooth. If it can't work on that helicopter, I don't think it can claim to work at all.
Besides, a quick google leads me to believe that this is not something isolated to my unit. There is many reports of this exact behavior from several years back and til now. And rarely does it seems to have been sorted. And then the day after my last flight a friend of mine had his helicopter demolished when a spirit pro drove it into the ground when hitting rescue. So I must say I'm about to loose faith now.
To me rescue have been the best that happened to helicopters since rotor blades, since it allow me to progress so much faster when the fear of trying new things are gone. But with the way my spirit gyro behaves that fear is right back where it was before rescue.
