[SOLVED] srxl2 AR6610T
latjo-k
tfmcnellist wrote:Anybody else give it a try? I know this is a trying time for everyone. Any update on this? Thanks for you help.
Havent recived the usb adapter yet,post the result later this week.
latjo-k
HI all
Im glad to announce that after update the AR6610T,ALL THE CHANNELS WORKS.
My TX DX9,so update and go flying!
//Lars
tfmcnellist
Updated my AR6610T and everything works. Had to reverse a few channels, re-assign Throttle to Channel 1 and re-assign the bank channel. Not a completely smooth transition but all seems to be working. We are on lockdown here in Illinois (USA) so it will be at least 3 weeks before we can fly.
Thank you very much for the reports!
We will put message about the firmware in the manual.
chris_0815
Tomas,
you've already mentioned that you don't want to mix SRXL2 and legacy stuff, e.g. an AR6610T and one of the old, non-SRXL2 remotes (AKA satellites).
If I understood you correctly, you rather suggest to add a new SRXL2 remote to the AR6610T for the bigger helis. Perfectly valid decision :)
But there are some advantages in the "mix" case (like the MSH brain supports it):
  • The cable between the Spirit and the AR6610T is not the single point of failure.
  • Those old remotes are much cheaper (at least second hand) and many of us have them already lying around.
  • The new remotes are hard to get at the moment, e.g. the SPM9747 has not yet hit the market.
Supporting additional SRXL2 remotes directly on the Spirit would give even further advantages:
  • AR6610T + SRXL2 remote costs more than just two SRXL2 remotes - set aside the builtin vario of the AR6610T that most of us heli pilots do not need :)
  • Let's say we use two SPM4651Ts which have full range telemetry as opposed to the short range telemetry of the SPM9747 (Spektrum calls that "Fly By Telemetry"):
    in case one of those two remotes does not "hear" the transmitter (you can detect that either due to missing the frame or interpret the RSSI value), you can use the other one to send the telemetry data and highly increase the chance of being "heard" by the transmitter.
What do you think about that? I assume most of the code needed (except for the last point of course) is already there.
chris
If you are using old Spektrum satellites, you can just get SPM4649T to make telemetry and integration to work.
The latest SRXL2 satellites are quite prone for brown outs alone while full size SRXL2 receiver have big capacitor to stabilize the voltage for them.
Spektrum never recommended to use even old satellites without receiver. But unfortunately people require this feature and use this widely.
But originally there was nothing like SRXL1 or SRXL2 protocols that made it similar to for example Futaba SBUS where people were connecting receivers just by single cable for long time.
Small JST cables were quite unreliable for receivers anyway.
Technically it is possible to mix this technology but I really can't see any good point for adding even more confusion. If problem is cost, then get SPM4649T. If not then get AR6610T and optionally SPM4651T.
The need for using old satellites will cease in short time. But supporting mix will make the transition only longer and add possible troubles and raise many additional questions.
SPM4651T SRXL2 satellite is available at nearly each RC eshop.
Can you tell me which firmware version is required in order to output more than 6 channels?
chris_0815
ZeXx86 wrote:Can you tell me which firmware version is required in order to output more than 6 channels?
If this is addressed to me - I don't know by hard since I do not own one. I bet it's in the linked thread, though.
Anyway, if you use the "Spektrum Programmer" to update it, it will tell you the version of the device as well as those available for update.
latjo-k will know for sure, since he already did the update :)
chris
latjo-k
The firmware is 2.34.1 ar6610t
chris_0815
ZeXx86 wrote:If you are using old Spektrum satellites, you can just get SPM4649T to make telemetry and integration to work.
That's right. Well documented and widely used. Stable and working solution :)
While that's perfectly true for the old remotes (since they need good 3.3 Volt stabilization), IMHO that's not true for the newer ones. They have a great range of input voltage (3,3 to 8,4 V) and of course I'd run them on the servo voltage - usually a HV, anyway.
And I can attach their signal line to different inputs of the Spirit - not just a single one like using a AR6610T + remote attached to the RX. In the latter case, there is only one signal line, hence a single point of failure.
[mix solution] ... raise many additional questions.
That is true. Could flood the support line :shock: Still, the MSH brain features it :mrgreen:
You're right, in the future the old stuff will become extinct.
And thinking of it again, I agree it is better to strive for simpler solutions instead of making things more complex.
The only thing that remains is the single cable. But that's the same with the serial protocols of all other vendors - correct? I don't know all of them ...
chris
