Re: Spirit GT Presure Sensor issue's
Posted: Mon 12. Jul 2021 14:57:44
I suspect that the problem must have to do when I setup the Heli first time, because as I mention earlier if the Heli conected to the computer by USB port the function works, if you disconected from the computer without switching of still works, but if you switch of the Heli and connect again the Heli to Fly, than not works.ZeXx86 wrote:Hello,
Rescue (Automatic) can be fully tested at any altitude. It is completely irelevant where you will try it to activate. It must work at any altitude, because unless the model is flying, it will act as when model is at 0 meter altitude. So it does not matter what Hard Deck limit you will set. It can be 1 or 50 and result will be same on the ground at any moment.
It also does not matter what Rescue is configured. Outcome must be same with any type on the ground, when model is skids down. Swashplate must go always to defined Rescue Collective Pitch value. Default is 60%. So 60% of your full collective pitch range. But I dont know what is your settings now.
If you can see rescue is going down, then it is 100% certain that the basic settings is not correct.
It is recommended to proceed exactly according Setup Wizard. Especially when there is Subtrim step.
Both Altitude Limit from GeoLink or Rescue (Automatic) will work when configured correctly. I can help you with each step, but first we have to make sure your basic settings is correct. It can be easily verified by enabling Servos/Subtrim (tuning) menu. All servos must go to neutral position - 0 angle - perpendiclar arm position. Swashplate must be exactly levelled and there must be 0° between main blades. Any other condition will result in a bad flight performance and incorrect Rescue behavior.
Also I suspect that the problem is when setup the Heli first time, and in the Stabi windows ( the problem is that by default are " Negative Gyro gain" activated .
The question is, if it be possible later on the Stabi window setup later to " Dedicated channel" because every time when I desactvate the function on the stabi window, appears this " Negative Gyro gain"
Just see that if you switch in the software Stabi windows in Demo mode, it appears the message" Now you can use with channel 7" and when you switch back Rescue , now you can use with negative Gyro gain, I never see this message when I connect in real by USP port to the Heli ?
One question, what happen if you cannot disconnect the function " Auto Rescue" when Flying.
How do you land the Heli. Obviously the Heli will stop to goes down at the parameter in meter pregrogrammed.
