Page 5 of 12
Re: spirit rs help
Posted: Mon 27. Feb 2023 20:37:05
by Mattes61
for me it is very hard to understand where your problem is because your english is very hard to understand -
the only advice I can give you is don't try to code and test everything at once, this makes it much more difficult to troubleshoot - if I were you I would code one thing first and then test if it behaves the way it does should be - if that then works, then also program the next one and test again - then you will recognize very quickly where the actual problem is - you may then have to interlock things with a logic so that they do not negatively affect each other -
This is really well intentioned advice, otherwise no one might be able to help you because it's very hard to understand - Sometimes it's better to start over and then test the way I suggested -
Best regards
Re: spirit rs help
Posted: Tue 28. Feb 2023 20:00:48
by franz88
ok i disabled everything.
Sorry for my english.
Spirit rs with geolink i just tried only limit altitude.
I tried on1 and on2.
maybe I don't understand because of english.
So I ask simple questions.
In this test the board Stabi - Function is set Disabled (I'm trying them all)
If i active on1 the model it goes very high and NOT IS NORMAL the helicopter must go up only for 1,5second.
10 meters 20 meters and after I disable it to stop it, because it is too high.
Now if i active limit altitude with on2 i set channel at the minimum possible -9% (below goes off).
In this mode the model gets up of 15meters and after stops and you are control again.
In this mode works well the only problem is that the model goes up 15 meters.
If I return at the altitude where I activated on2 repeats itself, the model goes up 15 meters and then I'm in control.
on2 works well, but it just goes too high the model.
Now I want to show you:
now exit triggering by geolink channel while before during my old tests exit triggering by stabi channel
i read the manual but maybe I misunderstand.
If i use on1 my helicopter it should go up 2 or 3 meters and after am I in control again?
and repeats this every time I go under the quota set from the moment I activate the limit altitude?
If i use on2 the only difference is that is adjusted by channel the quote in which it is activated limit altitude?
But during my tests with on2 is activated every time I arrive at the quota in which I activated the function and it means that I misunderstood the manual.
A question but with this update you tried limit altitude of geolink?
Everyone I know they only tried it with the old version.
Surely it's me who's wrong, but where am I wrong?
something is wrong here, please I want at least the automatic rescue, I bought this flybarless for this function.
Please help me i explained the problem
But during f geolink limit altitude in stabi - function what should i activate? (rescue normal, rescue acro, rescue by channel or it must be disabled?) today I tried with disabled and only geolink limit altitude activated.
The question is simply.
Why if I active limit altitude geolink with on1 the model always goes up.
With on1 when it should stop and give you the commands?
My problem it may depend from this parameter too high? (PS remember these tests stabi-functions is set disabled)
The helicopter after activating limit altitude of geolink does it have to get up for 1.5 seconds or gets up based on the value of rescue collective pitch?
This parameter works with on1 and on2?
this time you have understood?Did I write well?
Re: spirit rs help
Posted: Wed 01. Mar 2023 18:13:02
by Mattes61
please can you explain what you mean by "on1" or "on2", I did that not understand -
Can you perhaps make a video where we can see your screen, what you have programmed and what reaction the triggering of a switch has, also in your remote control - What is important in any case is that the switch states are programmed correctly in your remote control - As an example , Function deactivated means that the value in the remote control must be -100, for example. The function activated would then mean +100 as an example, but this only applies to switching states off or on -
Any analogue values for example for the corresponding rotation rate need intermediate values until the desired value is displayed -
Greetings
Re: spirit rs help
Posted: Thu 02. Mar 2023 1:48:11
by franz88
on1 and on2 are the modes to activate limit altitude of the geolink.
Today I've done it.
I activate with f geolink limit altitude (on1) and stabi -functions i set selected by channel.
just one question:
when active limit altitude in this mode as I decide how high to get the helicopter going?
Why i want to decrease how much goes up
Re: spirit rs help
Posted: Thu 02. Mar 2023 17:25:43
by Mattes61
The only one who can really explain this to you is Tomas himself or an experienced user with GeoLink experience- I myself have no experience with Geolink, so I'll just leave it at that - sorry!
Re: spirit rs help
Posted: Thu 02. Mar 2023 20:02:00
On 1 = you can define minimum limit directly from the time when you engage this function. Everytime you change switch position back to off and then on you are configuring new altitude for Altitude Limit.
On 2 = you can define altitude even if you are at the ground or in your home by changing channel value in other direction. There you will see in which altitude will trigger when function is active.
Re: spirit rs help
Posted: Sat 04. Mar 2023 20:49:46
by franz88
ok thanks Therefore I'd got it right.
When I activate limit altitude how do i decide how much should you raise the helicopter?
Now moving the parameters the helicopter gets up 7-10 meters for about 3-4 seconds.
I want make it go up for 3 meters for about 1,5 seconds.
This is my settings now
trex500.4ds
(255 Bytes) Downloaded 137 times
Re: spirit rs help
Posted: Tue 07. Mar 2023 18:57:13
by franz88
zex I have solved.
The limit altitude it gets activated and shashwplate went to the position set.
I had to decrease "Rescue collective pitch" at 40%.
In this mode i active altitude limit and the model go up for 1,5/2 seconds and go up of a few metres.
Now in this mode is perfect.
it's how I want it.
One thing I didn't understand.
Sometimes if spirit it gets a lot of vibrations to the point where a message comes out in the logs, the limit altitude for two or three times did not enter.
But I had tail rotor shaft that caused me high vibrations.
Why didn't it activate limit altitude?
After if I turn it off and on spirit and geolink limit altitude it works again.
But why sometimes limit altitude was not entered?
May be because of high vibrations?
Re: spirit rs help
Posted: Sun 12. Mar 2023 9:46:20
by franz88
now limit altitude, rescue normal, and return to home all right.
during a descent if you step give pitch aggressively what a parameter command this thing?
Re: spirit rs help
Posted: Tue 14. Mar 2023 10:03:50
by franz88
there is a mode for setting how much to correct return to home?
When I activate it tail responds aggressively.
For now I bought a pinion with an 1 extra tooth to get more rpm and having more stable helicopter see if i avoid this thing.
A gain identical the gyroscope maybe.
The update is out can i download it?
