Main Loop Hang Occured error
Mr.HillBilly
I started to get this error in my logs. Manual says it may be BEC but I run a 2nd. battery for the raido system so that is not the issue.
It has been flying great (still is even when I get the error) and nothing has been changed for at least 30 flights. No crashes or anything changed for a good bit of time, and I do not notice any glitches during the flight.
Any suggestions on what I should go looking for?
Goblin 700
Castle 160
Here is a log file from today.
00:10 Good Health Message 00:20 Good Health Message 00:30 Good Health Message 00:40 Good Health Message 00:50 Good Health Message 01:00 Good Health Message 01:10 Good Health Message 01:20 Rudder Limit Reached 01:30 Good Health Message 01:40 Governor was Engaged 01:50 Good Health Message 02:00 Good Health Message 02:10 Good Health Message 02:20 Good Health Message 02:30 Good Health Message 02:40 Good Health Message 02:50 Good Health Message 03:00 Good Health Message 03:10 Good Health Message 03:20 Good Health Message 03:30 Governor was Engaged 03:40 Good Health Message 03:50 Good Health Message 04:00 Good Health Message 04:10 Good Health Message 04:20 Good Health Message
04:30 Main Loop Hang Occured
04:40 Good Health Message 04:50 Good Health Message 05:00 Governor was Engaged 05:10 Rudder Limit Reached 05:20 Good Health Message 05:30 Good Health Message 05:40 Good Health Message 05:50 Good Health Message
06:00 Main Loop Hang Occured
06:10 Good Health Message 06:20 Good Health Message 06:30 Rudder Limit Reached 06:40 Good Health Message 06:50 Good Health Message 07:00 Good Health Message 07:10 Good Health Message 07:20 Rudder Limit Reached 07:30 Rudder Limit Reached 07:40 Good Health Message 07:50 Good Health Message 08:00 Good Health Message 08:10 Good Health Message 08:20 Good Health Message
are you using governor from the unit or from your ESC?
Mr.HillBilly
Running gov. in the Spirit. No BEC with the Castle 160 so I run a 2nd LiPo for the RX and Spirit power.
I have the speed controller in External Gov. mode, all soft start and such is done through the Spirit also.
