Rescue at full pitch
Angus
Hello I was bench testing the rescue on my Goblin 500, through out most pitch settings it works as described, but at full pitch it has a reverse rescue pitch ( not sure if this is right, at full pitch it has no more positive pitch to give but why negative?)
Thanks for any info
Angus
This is not a problem. It depends on your servo connection.
To solve the problem you can just move slider for the Rescue collective pitch to the negative value.
Then it will be good.
Angus
ZeXx86 wrote:This is not a problem. It depends on your servo connection.
I have everything working right but at 100% pitch rescue goes downward not up (there is no more up to go) it this correct or should there be no rescue movement at 100%
not that anyone fly's at 100 pitch very often
Angus
There should be rescue movement but always UP. It can be fixed by parameter Stabi/Collective pitch for the rescue so that you will set negative value.
