Rescue at full pitch
Posted: Sat 28. Nov 2015 22:57:34
by Angus
Hello I was bench testing the rescue on my Goblin 500, through out most pitch settings it works as described, but at full pitch it has a reverse rescue pitch ( not sure if this is right, at full pitch it has no more positive pitch to give but why negative?)
Thanks for any info
Angus
Re: Rescue at full pitch
Posted: Sun 29. Nov 2015 9:34:27
This is not a problem. It depends on your servo connection.
To solve the problem you can just move slider for the Rescue collective pitch to the negative value.
Then it will be good.
Posted: Mon 30. Nov 2015 0:14:22
by Angus
ZeXx86 wrote:This is not a problem. It depends on your servo connection.
I have everything working right but at 100% pitch rescue goes downward not up (there is no more up to go) it this correct or should there be no rescue movement at 100%
not that anyone fly's at 100 pitch very often
Angus
Posted: Mon 30. Nov 2015 10:06:34
There should be rescue movement but always UP. It can be fixed by parameter Stabi/Collective pitch for the rescue so that you will set negative value.
