another mounting question
Posted: Sat 16. Jan 2016 13:47:54
by Neilholt
Hi Guys just a quick question when mounting the spirit pro it says vertical and vertical (top) is there any difference ,mine is mounted vertical with the wires at the front
Re: another mounting question
Posted: Sat 16. Jan 2016 19:08:26
in your case you should select "Vertical". Then everything will be OK.
Posted: Sun 17. Jan 2016 15:13:59
by Neilholt
Thank you so is vertical top mean wires at top of spirirt
Posted: Sun 17. Jan 2016 17:41:15
Yes, exactly. With Vertical (Top) wires can be also at the bottom.
