Page 1 of 2
wow 2.0
Posted: Tue 23. Feb 2016 20:23:52
by john1127
This one might be set out to soon. I upgraded 2 electric and all went well. Had to move 1&3 on one but that was all.
Then I went to my nitro and all went bad. Spent 2 hrs after update and eventully had to go back to 1.3. All controls were wrong, and I mean bad, tried swapping 1&3 no good. trex 600 dfc N.
Re: wow 2.0
Posted: Tue 23. Feb 2016 20:28:05
by Coco66
Did you reset the reverses in the TX?
What do you mean with "all controls were wrong"? Diagnostic screen? Or not responding correctly to inputs?
I suggest to redo the setup from a clean situation, no reverses, correct CH2 and CH3, and go from there.
Re: wow 2.0
Posted: Tue 23. Feb 2016 20:41:27
by john1127
all inputs on diagnose sere right from trans. Justall on heli were wrong. throttle made rudder move, ect
Re: wow 2.0
Posted: Tue 23. Feb 2016 20:44:48
by Coco66
john1127 wrote:all inputs on diagnose sere right from trans. Justall on heli were wrong. throttle made rudder move, ect
Did you try saving the config, and rebooting the unit?
Re: wow 2.0
Posted: Tue 23. Feb 2016 21:11:17
by john1127
yes.
Re: wow 2.0
Posted: Tue 23. Feb 2016 21:59:03
by Coco66
Channels assignments got lost, this could be the only explanation....
Re: wow 2.0
Posted: Wed 24. Feb 2016 0:50:33
by john1127
need more help from spirit. thks
wow 2.0
Posted: Wed 24. Feb 2016 9:33:20
by jgiannakas
john1127 wrote:This one might be set out to soon. I upgraded 2 electric and all went well. Had to move 1&3 on one but that was all.
I'd strongly recommend that you redo the setup. Reset the unit to defaults upgrade and start over with the wizard. Also reset all channel reversals on the transmitter.
Re: wow 2.0
Posted: Wed 24. Feb 2016 9:35:31
by Coco66
jgiannakas wrote:john1127 wrote:This one might be set out to soon. I upgraded 2 electric and all went well. Had to move 1&3 on one but that was all.
I see we are on the same page.
Unfortunately, if I read correctly his last post, the OP wants to hear from the Spirit guys only.
Re: wow 2.0
Posted: Wed 24. Feb 2016 9:36:58
by jgiannakas
Coco66 wrote:jgiannakas wrote:john1127 wrote:This one might be set out to soon. I upgraded 2 electric and all went well. Had to move 1&3 on one but that was all.
+1. It just seems like an incorrect channel assignment that can be resolved in under 2 mins but to be on the safe side a clean start would be probably the best
