Swash wrong direction on E700
Joce
I just setup my TT E700 with the new 2.0.0 on a spirit pro.
Got all ok except swash should go down in positive collective.
I could solve this by reversing de collective channel in the transmitter but rescue collective is still in wrong ditection.
Is there a way to tell the fw that swash is reversed ?
Adrian
You should not change collective in TX. As I guess Diagnostics is now wrong.
You should reverse Servos Ch1, 2 and 3 in Spirit following the Wizzard steps, till pitch is correct.
Than things should all work.
Or you might run in the issue like trailing blades.
http://www.spirit-system.com/phpBB3/vie ... 651#p13651
Joce
Well I tried that but in this case, directions are reversed.
Just looking in other posts it seems thisis the same issue as for Coco66 with his 450X
http://spirit-system.com/phpBB3/viewtopic.php?t=1203
Adrian
Got the same in mind.....
Coco66
I think Tomáš will contact you since he can send you a firmware which is specific for trailing edge control.
They are currently implementing a specific setting in the official firmware/software, but meanwhile I got the "unofficial" one and it works perfectly (flown it already).
Joce
Thanks Coco ! Will try that when I get it.
Joce
I didn't receive any update but I could fly just like that : reversing the pitch channel and switching from rescue to stabilisation.
The E700 maiden went very well.
Just one thing : in fast circles in good wind the pitch was a bit too sensitive. The heli was going up and down without real will to do that on the sticks. But this is my first 700 probably nothing important.
I have not received any message from you yet. But I will send you a link for the firmware.I highly not recommend to reverse pitch. It must be configured properly else other functions will not work.
Joce
Hi Tomas, sorry I didn't request the fw directly to you.
Thanks for the link in pm anyway.
Will use it obviously on my next flight !
Helmet
Any idea of when an official fw supporting trailing edge/reverse swash operation, will be released? I have 2 Raptors and a 360 CFX rescuing downwards. :?
