Im i suppose to save the changes I make manually? If I disconnect it says changes are not saved.
Re: Bluetooth +app not saving changes
Posted: Sun 13. Mar 2016 16:29:45
It works in the same way as the PC software.
You should save settings to the unit if you want to store it permanently (not loose with a battery disconnection).
Posted: Sun 13. Mar 2016 17:02:43
by velocity90
Ok where can I find the save function?
Posted: Sun 13. Mar 2016 17:08:14
In the context menu - there are many other functions as well. Just press the Menu button or "3 lines" icon.
Posted: Sun 13. Mar 2016 17:59:13
by velocity90
That explains, menu button not working on my nexus 9 tablet . (Android marshmallow)
It does on my phone(kitkat)
Posted: Sun 13. Mar 2016 22:31:40
by error414
you can tap to "three blue dots" on top-right on screen or you can slide from left to right and then tap to "menu"
check this
Posted: Sun 13. Mar 2016 23:15:09
by velocity90
I know, doesn't work on my nexus 9 (marshmallow) does on kitkat
Posted: Mon 14. Mar 2016 0:01:28
by Coco66
velocity90 wrote:I know, doesn't work on my nexus 9 (marshmallow) does on kitkat
Also sliding does not work?
Posted: Mon 14. Mar 2016 5:44:27
by velocity90
Sliding does work but the menu button does nothing
Posted: Mon 14. Mar 2016 10:10:08
by error414
hmm this is problem Do you use android from google or some custom ROM? It seem that I have to rewrite menu in android app.
