Bank selection with DX6i
delfo
Hello, can someone help me put bank selection with a DX6i radio and satellite DSMX?
Thank you
the easiest way is this:
1. Unassign Gyro Gain function in the General/Channels window.
2. Assign Banks function to the Channel 5
3. Set Gyro Gain in your transmitter to 0% and 100% - this will allow Bank 0 and Bank 2. 50% is for Bank 1, but DX6i has only two state switch (but you can use Mix in your transmitter to allow all 3 banks)
From now, your Rudder Gain will be configured in the software in the Sensor tab and your Bank switching will work.
If it will work correctly you will see in the Diagnostic tab that Banks are changng when you are moving with the switch.
delfo
Ok thanks for the replay, but when I insert the rescue (bank 2) with the helicopter tilted I do not see any plate movement and does not increase the pace. :?
For testing the banks, you have to close the software. When software is running, banks are switched through this.
