[SOLVED] Spirit Pro sometimes doesn't connect to transmitter
Posted: Fri 18. Nov 2016 19:35:12
by UFOking
I have 2 Spektrum DSMX satellites connected to my Spirit Pro and they sometimes won't connect to my transmitter.
When I connect the battery, the lights on the 2 satellites start to blink as if they were in binding mode.
I than have to reconnect the battery to get a connection. Sometimes I have to reconnect it more than once.
I also have a regular Spirit with also 2 dsmx satellites and never experienced that...
Thanks!
Re: Spirit Pro sometimes doesn't connect to my transmitter
Posted: Fri 18. Nov 2016 23:12:11
that is interesting. Do you have something connected in the ELE/PIT/AIL or SYS port when it happen? (For example some module)
This could possibly trigger the binding procedure.
Posted: Sat 19. Nov 2016 10:56:50
by UFOking
yes, the WiFi module is connected to SYS port.
Posted: Sat 19. Nov 2016 11:16:26
Ah, in this case - is the WiFi module updated to the latest version? If no, then the problem is just there.
Posted: Sat 19. Nov 2016 11:35:44
by UFOking
Indeed it is the WIFi module.
I disconnected it from the SYS port and and it connects with my transmitter every time.
But the funny thing is, that the module is updated to the latest version.
Posted: Sat 19. Nov 2016 15:49:56
Hmm, thats strange. Can you please verify with the web browser, what version you can see there?
You can connect to the module with PC or smartphone and enter the web page: http://192.168.4.1
Then you should see the version.
Posted: Sat 19. Nov 2016 16:11:08
by UFOking
I see version 2.2.0
Posted: Mon 21. Nov 2016 9:23:45
by UFOking
any news about my problem?
Thanks!
Posted: Mon 21. Nov 2016 9:43:58
we have modified the firmware to be less sensitive for binding, but this change will show up in the next version.
If you are interested in testing it, we can provide you the firmware right now.
Posted: Mon 21. Nov 2016 10:01:30
by UFOking
OK, Thanks!
