DSMX Bind problem.
Bravo
Using DX6i. and two DSMX sats
Just received the Spirit pro today.
It has the latest firmware and connects to the pc ok.
I've tried 4 different sats with the same result.
Sat leds glow steady orange. Status on Spirit pro goes on and off, color red, at a slow pace.
Never saw rapid blinking on sats and status light never goes out.
Thanks for the help.
Larry
Also...
Did connect to PC and set RX type as DSMX/2
first from all, you have to start the software and set the Receiver type to the Spektrum DSM2/X. Then it is very important to save the settings (with CTRL+S or in the Backup tab).
After this, you can connect the bind plug and start the unit again.
Then it should bind the satellite (including blinking).
Bravo
Thank you.
Works now.
Thought I had clicked on SAVE....but evidently did not.
Cheers,
Larry
Perfect, you are welcome!
