bad Tailperformance
Posted: Sun 02. Apr 2017 20:24:25
by Bjoern_ve
Hello everybody,
First the setup:
Gaui X3
SP Servos: Servoking 999
Tailservo: Servoking 795i
Blades: Zeal 360mm
Tailblades: Zeal 69mm
My problem is that I turn with Pitchpumps the tail away, I've already tried with all the settings but without success. Now I have gone to increase the speed at the tail and use other blades. Now the Tail holds but I get already with Pitchpumps a tremble, so I must reduce the sensitivity so strongly that everything is again as in the beginning. Someone has an idea.
What I noticed is that I have to keep the sensitivity very low, currently I am at about 20 at the low speed, at higher, that would be already almost 0.
Björn
Re: bad Tailperformance
Posted: Sun 02. Apr 2017 20:38:49
first from all you have to put a shorter servo arm (maybe 2 holes).
Then decrease Pirouette Consistency value to 165-170.
Then increase gyro gain.
And then it will be much better :)
