[ Version 2.4 released! ]
Version 2.4.0 was released!
It brings many new features and improvements:
  • Support for μSpirit unit:
    • Full support of the micro Spirit.
    • Compatible with all peripherals.
    • Can be used on helicopters of 130 - 250 size.
    • Support for ESC/Motor driven rudder.
    • New parameter Rudder - Control type to allow selection of the rudder drive.
    • NOTE: Will be supported by Spirit Aero firmware.
    • IMPORTANT: Older firmwares are not supported!
  • Graupner HoTT integration:
    • ESC Telemetry support.
    • USB interface can be connected without repowering the unit - once integration cable is plugged off, the status led will be turned off and you can plug in the USB interface.
    • Small speed optimization of the integration.
    • Support for μSpirit.
  • OpenTX Integration:
    • Significantly faster telemetry data refresh rate.
  • JETI Duplex Integration:
    • Telemetry data rate was optimized.
    • Support for Servo reverse CH0 for CCPM 90 swashplate.
    • Support for Subtrim CH0 for CCPM 90 swashplate.
  • In-Flight Vibration Analysis:
    • FIX: Can be used with F: Stabi function.
    • Can be activated all the time with no downside effect.
  • ESC Telemetry:
    • Support for telemetry data from the ESC - all data can be displayed directly in your radio.
    • Available for JETI Duplex, FrSky/OpenTX, Graupner HoTT.
    • New Telem CC, Telem UNI and Telem KONTRONIK telemetry cables.
    • Castle Creations Phoenix and Edge:
      • Battery Voltage
      • Battery Current (experimental)
      • BEC Voltage
      • Consumed Capacity (experimental)
      • ESC Temperature
    • HobbyWing Platinum V4:
      • Battery Voltage
      • ESC Temperature
    • Scorpion Tribunus:
      • Battery Voltage
      • Battery Current
      • BEC Voltage
      • Consumed Capacity
      • ESC Temperature
    • Kontronik Kosmik and Jive Pro:
      • Battery Voltage
      • Battery Current
      • BEC Voltage
      • Consumed Capacity
      • ESC Temperature
    • NOTE: All telemetry guides are available at the Wiki pages.
  • Wifi-Link module:
    • Support for the latest 2.4 firmware.
    • Support for the ESC Telemetry.
    • Support for the μSpirit.
    • Improved detection of the firmware version with more clear messages.
  • Spirit Settings - Android:
  • Spirit Settings - FreeBSD:
    • Launch scripts for better architecture detection updated.
    • Stability was enhanced.
  • Improved Setup Wizard:
    • New schemes with μSpirit.
    • Improved detection of the unit swapping..
    • New Profiles: T-Rex 150, T-Rex 250, Oxy 2, Blade 130S, Blade 180CFX, Blade 230S.
  • Governor:
    • Sensor Activity analyser was improved to work with all governor sensors.
Update for the Spirit unit, Wifi-Link and Jeti Integration is available in our Download section.
You do not have to change any settings after the update from the previous version 2.3.
Version 2.4.1 was released!
    • Telemetry connection is active also when the telemetry cable is disconnected - feature introduced in 2.4.0 was replaced.
    • USB interface can be connected once you will select the USB connection in the Expert menu (integration).
    • Speed optimization was reverted to increase compatibility.
  • ESC Telemetry:
    • Added support for the RPM readout from all supported ESCs - when no RPM sensor is connected, readout is taken from the ESC.
    • Added support for the Kontronik Jive ESC.
    • Kontronik Jive parameters:
      • Battery Voltage
      • Battery Current
      • BEC Voltage
      • Consumed Capacity
      • ESC Temperature
      • RPM
    • Added Imotor Shunt parameter - correction factor of the Current/Capacity.
    • Castle Creations Talon:
      • Temperature measurement was fixed.
      • Battery Current and Capacity measurement precision corrected for all models.
      • Big thanks to HobbyWing, Adrian, TomasN and our pilots!
  • Rudder stopping performance:
    • Stopping was enhanced to make it more equal when torque is too assymetric.
  • Stabilisation mode:
    • Stabilisation algorithm was slightly enhanced to make it more stable when Direction Control Rate - 0 is configured.
  • Wifi-Link and Jeti integration:
    • Support for the latest firmware 2.4.1 - update available for download.
You do not have to change any settings after the update from the previous version 2.3 and 2.4.0.
Version 2.4.2 was released!
    • Added new Telemetry variable - Throttle PWM [ms] - reported under Climb rate.
  • OpenTX integration:
    • New diagnostic script for displaying channel values - script diagnostic.lua.
    • Full support for the Log Viewer - script logviewer.lua.
    • Added configuration for the ESC Telemetry.
    • Added new Telemetry variable - Throttle PWM [µs]
  • Jeti integration:
    • RPM readout can't overflow - the max. value is 8191.
  • ESC Telemetry:
    • Castle Creations:
      • Telemetry readout is stable also when Spirit Governor is enabled.
      • Fixed capacity calculation when Spirit Governor is enabled.
    • Kontronik Kosmik & Jive Pro:
      • RPM: readout is compatible with all configurations now.
      • HobbyWing v4 120A: temperature calculation was corrected.
  • Manual:
    • New Chinese traslation was added! (Big Thanks to Mr. Wong)
    • Pin layout for Spirit and µSpirit units is available.
  • Spirit Settings:
    • Real-Time tuning:
      • When special function is assigned but channel is unassigned, the function will be automatically unassigned when window is closed.
    • Translation:
    • Setup Wizard:
      • Updated profiles for T-Rex 150, T-Rex 250, Blade 130S, Blade 230S, Oxy 2 and Oxy 3.
    • News noticement:
      • Automatic noticement of a new available updates.
You do not have to change any settings after the update from the previous version 2.3 and 2.4.x.
Update for the Spirit units and OpenTX Integration is available in our Download section.
