Esc telemetry hobbywing v4 60A
Posted: Sun 14. May 2017 16:36:26
by torro
Will battery current and consumed capacity be available in near future?
Greets, Flo
Re: Esc telemetry hobbywing v4 60A
Posted: Sun 14. May 2017 16:39:09
unfortunately no, this ESC does not support current measurement, which mean that also capacity measurement is not possible.
Posted: Sun 14. May 2017 16:44:35
by torro
Ok, Thanks
Posted: Mon 15. May 2017 7:31:27
by torro
Where can ich find this little white plug?
I need to make the cable.
Something special about the pin assignement?
Greets, Flo
Posted: Mon 15. May 2017 9:16:05
You can buy the cable from our eshop.
Connector that is used is one that can be found with Spektrum cables. Normally it is not available in end-user stores.
If you will buy a Spektrum cable it will probably be more expensive than our finished cable.
You need also special crimping tool from JST for the connector.
You can try to find a JST to Servo adaptor cable, the only thing you have to do is to disconnect red wire (positive).
Only ground and signal wires must be present.
Posted: Mon 15. May 2017 10:31:09
by torro
The cable is on backorder in your store
I have crimping pliers for jst xh and the Standard servo plugs.
The little white plug seems to be much smaller than jst xh. But i could buy a Spektrum cable and crimp my own servo plug on it.
Posted: Mon 15. May 2017 10:33:25
by torro
Would this fit?
http://m.ebay.de/itm/1x-Spektrum-Satell ... nav=SEARCH
Spektrum satellite cable 90cm.
Thanks!
