Telemetry Alert (vibration level)
Posted: Sat 20. May 2017 8:23:31
by Windsurfer1976
Hi Thomas, since the spirit measures the vibration level, it would be great to set up a telemetry alert, if it exceeds a specified range.
For example, if telemetrie reports vibration level via hott or jeti between 1-13 in flight, one could set 18 as alert limit.
So, if there is a mechanical failure in flying, this could warn the pilot to land.
Hope u understand my suggestion.
Greetings Andreas
Gesendet von meinem SM-G800F mit Tapatalk
Re: Telemetry Alert (vibration level)
Posted: Sat 20. May 2017 8:27:26
by Windsurfer1976
I think this could be helpful for scale helis. For 3d pilots, the vibration range would be to wide.
Posted: Sat 20. May 2017 14:39:31
with Jeti and FrSky this feature can be programmed in your transmitter.
For HoTT it is possible only by our implementation - we already plan to add alarms for HoTT, so in future it will be there
Thank you for suggestion.
Posted: Sat 20. May 2017 18:45:33
by Windsurfer1976
Thanks a lot Thomas [THUMBS UP SIGN][SMILING FACE WITH OPEN MOUTH AND TIGHTLY-CLOSED EYES]
Posted: Mon 19. Jun 2017 8:30:49
by martino
Hopefully, you also plan to implement an alarm for consumed capacity as well ?
Would be great.
Telemetry works nearly perfect with an RCE-BL130A (I miss BEC voltage
but no idea whether or not the ESC provides the data...). On the other hand,
another telemetry screen shows the receiver voltage, so no problem at all.
