im using a hott system with Gr-16 receiver and a mz-24 Sender.
As i use the sumd connection all channels are used by the system (Gyro, bank Switch included). I would like to use more than 8 channels on my gr-16 as i use the sumd connection (i need few more for led controller). But there is a issue with the channel mapping. The channels 8-12 can only be used by special functions.
It would be great if it will be possible to map the bank switching or gyro sens on chanels 8-12. Then i could use the free ports on my gr-16 via mapping to control my led controller.
Hope u understand my problem
Greetings Andreas
