[SOLVED] Taildragger inialazation
RidgeMan
I noticed the note:
Warning: If using these modes, be sure your model is initialized on a flat surface, not tilted to any side. Do not tilt the model for more than 5 seconds after initialization. It can be initialized in normal or inverted position.
Does this mean that you would have to hold the tail on a taildragger level during power up? Or just keep the wings level?
Such angle as are present in taildragger models is not a problem, but bigger could be.
So just initialize the model in normal position and fly.
