RPM displayed on Jeti DS16 - using Scorpion governor
Posted: Wed 20. Sep 2017 18:25:57
by Malc1
I am using the internal governor on a Scorpion Tribunus 200A esc and have RPM data being displayed on my Jeti TX.
Will this be the correct RPM being displayed?
I have noticed that in the Scorpion software when running the motor the RPM is much much higher and certainly can not be the RPM of the rotor head.
Or do I need to be using the Spirit governor for this work correctly, and be able to use it to set up the helicopter?
I have previously set up the correct main gear ratio in the Spirit software.
Re: RPM displayed on Jeti DS16 - using Scorpion governor
Posted: Wed 20. Sep 2017 18:34:38
You have to set Sensing Divider and Gear Ratio. Then it should match the head speed. This can be done in the General - Governor/Throttle window (after enabling Governor temporarily).
Posted: Wed 20. Sep 2017 19:47:07
by Malc1
Great! Many thanks again.
