[SOLVED] Hobbywing 130 V4 and Telem UNI cable with DS16?
Franky13
Hello!
I have a few problems with the Telem UNI with the Hobbywing 130 controller.
As far as described I have everything connected correctly. In the DS16 I have the ads; Temp, Cap, RPM, Volt, Current, Vips, but they are all zero? Only temp is at 25.5 degrees.
Software is up to date!
What can I do?
Greeting Frank
Hello Frank.
Please check firmware in the ESC. Older version does not support the telemetry.
You can also verify if you are using the primary satellite port.
Franky13
Hello Tomas!
Because of a shorter cable laying in the TDF, I used the Secondary Port.
I have now connected the primary port.
Now I have all the ads in the DS16 !!! :D
Thank you!
Great! It must be always at primary port.
