jeti radio spirit system and servos
Posted: Tue 03. Oct 2017 12:45:34
by Helichef
hi I asked this question in the wrong section I think this is the correct area now.
heli tail servo and the others not moving after the initial set up process is done in spirit wizard.
I think I read somewhere some time ago about doing something in the radio cant quite remember what it was.help needed
Re: jeti radio spirit system and servos
Posted: Tue 03. Oct 2017 13:32:14
is LED on the unit steady ON?
Were the servos moving at any point?
Normally there is no reason other than that the servos are plugged incorrectly in the unit.
You can take a photo of the connection so we can check it.
Posted: Wed 04. Oct 2017 19:36:27
by Helichef
hi I'm using a r7 plus receiver only rudder is moving I have stsndard classic receiver checked in the set up section but when I reach to the servo set up section nothing happens
Posted: Wed 04. Oct 2017 20:04:50
At that time the wizard is still not communicating with the unit so it is not important what you will select in the software.
I think that problem could be in the connection of the servos.
Can you take a photo of the unit with connected servos, please?
Posted: Thu 05. Oct 2017 0:43:03
by Helichef
Posted: Thu 05. Oct 2017 0:43:36
by Helichef
I hope it's clear enough
Posted: Thu 05. Oct 2017 8:16:42
Thank you very much for the photo.
It looks good.
Did you selected PWM connection type in the Setup wizard?
What I can recommend is to use UDI or EX Bus connection, since it is digital connection.
With EX Bus you can also get full integration with the Jeti radio - it is just one cable instead of 3.
Posted: Tue 17. Oct 2017 15:32:55
by Helichef
Im sorry how can I do that or should I go to the connection page in the manual?
Posted: Tue 17. Oct 2017 15:46:38
