Aileron Differential
Posted: Sun 10. Dec 2017 23:11:13
by donskills
Does the aileron differential parameter in the Spirit work like conventional differential and decrease the downward movement of the ailerons? The manual for the Ultimate suggests 40 degrees up and 35 degrees down at full throws. How do I achieve this in the Spirit?
Re: Aileron Differential
Posted: Mon 11. Dec 2017 10:53:23
Yes, it is working in this way. You can just set it at 87% to achieve what you wish.
Posted: Mon 11. Dec 2017 11:29:21
by donskills
Thank you Tomas!! Best support as always!
Sent from my iPhone using Tapatalk Pro
Posted: Mon 11. Dec 2017 19:27:05
by donskills
Tomas; the 0% aileron differential default setting means its off? I would have guessed to set about 11% to reduce throw from 40 to 35 degrees. Just so I dont mess things up!
Posted: Mon 11. Dec 2017 20:49:41
by donskills
It is as I suspected, I set aileron diff at 13%. Looke about right on the bench
Posted: Tue 12. Dec 2017 8:19:41
Oops, yes, you are perfectly right.
Just calculator was giving incorrect value (opposite)
You can calculate it in this way:
value = (1 - (35 / 40)) * 100
