ESC Throttle Cable Channel Question
sawacs
I am setting up a Spirit Pro FBL on my Trex 700x and have a question regarding the throttle cable.
Specs:
Spirit Pro
Jeti DS-16
Jeti REX10 with a R3RSW in dual path
Hobbywing 120a V4
Where exactly should the esc throttle cable be plugged in on the Spirit Pro?
I have the following channels:
Aux1
Aux2
Chan 0
Lastly, I will be using the Hobbywing governor rather than the Spirit governor
Thanks!
Update: I figured out where the connection goes and everything is working great.
Cheers!
Syngorextor
sawacs wrote:I am setting up a Spirit Pro FBL on my Trex 700x and have a question regarding the throttle cable.
Specs:
Spirit Pro
Jeti DS-16
Hobbywing 120a V4
Aux1
Aux2
Chan 0
Thanks!
Cheers! :)
I Believe on AUX1 channel, but please double check the manual...hope this help and good luck.
Yes, it is AUX0 port as described in the manual (Wiring section).
