HW 60A v4 + REX7 + Spirit pro wiring
demon450
I did some research but not found a complete guide about wiring, I think I should connect this way:
ESC to AUX1, ESC programming port to SAT port
RUD and AIL to EXT on REX7
I wonder if the Tele UNI cable is a simple adapter or there are chips inside? Can I make it myself? I ordered everything but missed this cable :(
you can find complete wiring here:
http://manual.spirit-system.com/index.p ... S_RECEIVER
and here:
and here:
Telem UNI is special cable, but you can make it yourself. But if done wrong, it will damage unit or the ESC. It is normal adaptor, but inside there is red wire (positive) disconnected.
demon450
ZeXx86 wrote:Hello,
and here:
and here:
It looks pretty simple to just cut off red wire and make an adapter.
Thanks a lot! Great support as always.
Yes, it is possible to do it in this way :)
You are welcome.
