Question on mounting the Spirit
Posted: Tue 27. Feb 2018 4:45:25
by ryguy76
I am finishing up on a new Oxy 4 build and noticed that the boom clamp has a slight seam between the mating pieces. If I place the Spirit in the middle of the boom clamp, I can rock the FBL from side to side slightly due to the high center of the seam. I had used the white foam tape to mount the Spirit and it looked a little off-level to the eye. Is this something that really matters? Does it need to be perfectly level or is this my OCD getting in the way?
Thanks in advance.
Re: Question on mounting the Spirit
Posted: Tue 27. Feb 2018 8:10:56
in that case it is better to cut two pieces of the tape and make a kind of rails under the unit.
so that in the middle there is nothing.
More precisely the unit is mounted, more precisely it will fly.
Posted: Tue 27. Feb 2018 21:08:12
by ryguy76
Thanks Tomas.
