Hobbywing SCM connection ?
Dawiev
HW released the module (SCM) to correct the telemetry for their OPTO modules. I'm using a 200A ESC.
With Spirit, the connection only takes the signal pin from the RPM port.
What is the correct way to connect this new module please ?
RPM_Telemetryen_Manual.pdf
(1.47 MiB) Downloaded 104 times
the R with Signal out will be connected by a single wire with the PIT pin or by a servo cable with middle pin removed (very important).
The telemetry (P) port (Signal out side) will be connected by the Telem UNI cable.
Dawiev
Thanks! !
