[SOLVED] Geomety 6deg setup
Posted: Sat 13. Sep 2014 9:22:22
by ChrisTTian667
Hey,
i am currently setting up the 6deg geometry. But i can't manage it to be 6deg. When i set the value to 90 i have still 7,2deq.
Can anybody explain me which (hardware) parameters i have to change to get the 6deq and maybe why?? The configuration app tolds me, that i may change the hole on the servor arms. But this would be impossible without loosing the 90deg at 0-Pitch.
thanx for your help!
Re: Geomety 6deg setup
Posted: Sat 13. Sep 2014 10:02:39
what helicopter it is?
Some models can't achieve ideal geometry setup, but ths is not a problem at all and flying very well.
For example TRex 550 DFC has only about 70, so you can decrease the value.
Posted: Sat 13. Sep 2014 17:08:16
by ChrisTTian667
Aahhh. Ok. Its an Trex 550 FBL V2
Posted: Tue 30. Sep 2014 11:50:28
by Marian
ChrisTTian667 wrote:Aahhh. Ok. Its an Trex 550 FBL V2
To help lower the mechanical gain of the head you can use shorter ball links on the inner swashplate ring. Those ball links where the dfc arms are connected from the main blade grips to. Those shorter ball links can be found in the Trex 700 kit of ball links sold by Align.
