Gobl. Fireball swashplate wrong direction in default setting
Posted: Mon 17. Dec 2018 13:57:12
by Mattes61
Hello Tomas,
I have an question - I think the direction of the swashplate (inverse 120 °) in the setup wizard is not right. The correct direction has to be 120° because look at the attched files -
Am I right ?
Best wishes
Matthias
Attach: The attached files are hardcopys out of spirit setup wizzard an sab fireball manual
Re: Gobl. Fireball swashplate wrong direction in default set
Posted: Tue 18. Dec 2018 21:39:44
you are right that for this helicopter CCPM 120 is the right setting.
If you will re-download the Spirit Settings it will be all fine :)
Regarding Throttle indicator it seems that your throttle value is way too low when Throttle Hold is engaged. It should be closer to 0%. Then it will be fine.
Posted: Wed 19. Dec 2018 14:14:03
by Mattes61
Hello Tomas !
Thanks for your great support :D
I wish you a merry chrismas and a good time !
Best regards
Matthias
