Cyclic Servos are shaking
commonrailer
I am setting up my new spirit pro. All components like servos, RX, FBL are placed on the desk. After initialization, the servos starts to move with strong shakings when I change the FBL unit orientation by hand. Is this a normal behaviour or should there a smooth movement of the servos?
Best regards
Walter
The unit should respond to the movements. Once unit will be mounted at the model it will look very differently, because hands can't make smooth movements with a small things. So I am convinced it is normal.
commonrailer
Ok. Thanks for quick reply. If I notice further servo shaking on mounted system I will contact you.
