uSpirit - power capacity
Bladecrasher
I would like to use a uSpirit I already own on a Blade 270 which uses the Spektrum H3050 and H3060 servos. Are those servos going to pull to much current for the power-bus in the uSpirit?
I believe these servos are the same as what is used with the 230s.
Thoughts...
They are just fine for uSpirit.
uSpirit can handle micro servos without any problem.
Juan Cobo
I have the doubt if the uspirit can go well in a minicomet, by size I would be much better, is it possible?
You will need 4x JST-Servo adapters. Then it will work. But normal Spirit unit is just fine for Mini Comet.
