[SOLVED] SpiritPro doesn't react on RX signals
scvflyer
Hello serviceteam,
after a crash - I rebuild the system and did an software update for SpiritPro to 2.6.1.
But no channel signal from TX/RX recognized at SpiritPro - no physical reaction nor at diagnose screens at spirit software.
Current status:
* TX and Receiver has been changed to be sure that this part is fine - SUMD (test with Graupner) and SBUS (test with FrSky)
* Init phase seems to be okay - TS and Servos will be centered properly - but red light flashs
* BEC Test works well
* Adjusting Servo to get TS zero position - works well
* Reset to factory setting has no effect
Any idea
thanks and br siggi
please make sure that the correct Receiver type is configured in the Spirit Settings and that it will persist after re-power.
I guess that the problem is just there.
scvflyer
you are right - re-power is the magic thing
thanks and br siggi
