Spirit unit + Graupner MX-20 + Graupner GR-16 + UniSens-E
pidder
Hi, my question is regarding the above metioned setup.
I use UniSens-E (under Graupner HOTT as GAM)to detect the used capacity and let the receiver tell me by using a switch.
Now - with the sprirt unit i have to decide whether i will use telemetry port for spirit setup or to use the UniSens-E unit.
My question: Is there any possible wireing to have both functions possible via the telemtry port? :?
regards
Peter
TomasN
Yes, you can use Y-cable. But before connecting of both components you have to set UnisensE or Spirit to EAM mode instead of GAM.
TomasN
See http://manual.spirit-system.com/index.p ... _Emulation how to change sensor emulation mode for Spirit
pidder
TomasN wrote:See http://manual.spirit-system.com/index.p ... _Emulation how to change sensor emulation mode for Spirit
this - i will try this - but what about the wires?
The unisons needs the red cable for power-supply. It is recommended that on the SYS-port of the spirit the must not be any voltage!!!
Did you cut the red wire or is it no problem?
TomasN
Use plus, gnd and signal between Unisens and receiver. And connect signal from receiver to Spirit. GND is already connected by another cable.
pidder
TomasN wrote:Use plus, gnd and signal between Unisens and receiver. And connect signal from receiver to Spirit. GND is already connected by another cable.
Thank you very much - i will try this!!!
pidder
I tried this an it works!!!!! :D :D
Great job thank you very much for your help!
Peter
enied
Hi TomasN,
does it harm to connect GND ? Currently I have connected it and it works.
Thank you in advance for your feedback.
Best, Eugen
TomasN
Connecting also GND is ok . But single signal wire is enough and simplier.
enied
Thank you !
