Page 1 of 2
[SOLVED] 4dsviewer
Posted: Thu 12. Dec 2019 20:19:54
by FrankFuss
Hi Tomáš, will there be an update to the 4dsviewer for the latest firmware version 2.7.1? I know you have other higher priorities. Keep up the good work.
Re: 4dsviewer
Posted: Thu 12. Dec 2019 21:18:46
it will be updated as always. There is no reason to not update it
Re: 4dsviewer
Posted: Mon 16. Dec 2019 18:07:14
by Genesis
Hi Tomas,
Is there a new link for profile viewer as the link in the settings tab does not work with 2.7.1 profiles, only 2.6.4 and older. Thanks in advance.
Best regards,
Kevin
Re: 4dsviewer
Posted: Sun 22. Dec 2019 16:19:19
by Genesis
Tomas,
When can we expect a new viewer update to be available?
Best regards,
Kevin
Re: 4dsviewer
Posted: Sat 28. Dec 2019 18:39:16
by jjuk
+1
Just setting up a heli and would like to use the viewer for 2.7.1
Re: 4dsviewer
Posted: Thu 23. Jan 2020 23:55:43
by Genesis
Still no updated viewer
Re: 4dsviewer
Posted: Fri 24. Jan 2020 9:16:10
it should already work.
Re: 4dsviewer
Posted: Fri 24. Jan 2020 9:19:28
by jjuk
It doesn't for 2.7.1 last time I tried it.
Re: 4dsviewer
Posted: Fri 24. Jan 2020 9:27:53
You can try again
Re: [SOLVED] 4dsviewer
Posted: Fri 24. Jan 2020 13:38:22
by FrankFuss
It looks like "Stabi -> Rescue collective pitch" is not being displayed correctly for a 2.7.1 4DS file.
