Page 1 of 2
Very high values in OpenTX Telemetry
Posted: Thu 23. Jan 2020 7:34:40
by ferdey
Just asking this in here, probably not a Spirit issue at all, just checking? Maybe related to OpenTX v2.3.5, on a Taranis X9D+ with a Hobbywing 200A ESC and Spirit Pro. Suddenly I see random very high numbers in Telemetry, such as for ESC Temp max and RPM min (looks like Int32 Max to me).
Any suggestions where to look?
Cheers!
Re: Very high values in OpenTX Telemetry
Posted: Thu 23. Jan 2020 8:59:07
are you able to downgrade OpenTX firmware and compare the results?
Posted: Thu 23. Jan 2020 12:03:16
by Mikej
I have these also - but in my case for Fuel +, which I was using to see maximum vibes
This is with OpenTx 2.3.5, the latest V2.0.1 ACCST firmware using micro Spirit with HW integration and OpenTx integration (2.7.1 version). I foolishly changed the ACCST firmware, Changed the OpenTx firmware and added Fuel+ to my telemetry screen all on the same day so I don't know which one introduced the problem :(
Posted: Thu 23. Jan 2020 19:41:48
by ferdey
ZeXx86 wrote:Hi,
Thanks, yes, I think I will do this. It is looking like an ACCST D16 2.0.1 firmware issue.
Posted: Thu 23. Jan 2020 19:43:03
by ferdey
Mikej wrote:I have these also - but in my case for Fuel +, which I was using to see maximum vibes
Yep, that's what I am seeing exactly, I will go back to v1 ACCST D16 firmware I think.
Posted: Fri 24. Jan 2020 5:47:11
by ferdey
I've rolled back to the latest v1 ACCST firmware on my tx and rxs and so far it has not happened again, thanks (although still running OpenTX v2.3.5)
Posted: Fri 24. Jan 2020 17:02:46
by Mikej
Thanks for updating on this - I've only seen it on Fuel+, but I also get a lot of "Sensor Lost" warnings with the V2.0.1, and Fuel+ will keep the weird value as it is a maximum field whereas the other sensors will get overwritten.
Posted: Fri 24. Jan 2020 21:00:55
by ferdey
Mikej wrote:Thanks for updating on this - I've only seen it on Fuel+, but I also get a lot of "Sensor Lost" warnings with the V2.0.1, and Fuel+ will keep the weird value as it is a maximum field whereas the other sensors will get overwritten.
No worries :) I was midly worried when I got an ESC Temp warning 12 seconds into a flight and I glanced down and saw the ESC temp was around 62 million degrees C lol
Posted: Sun 26. Jan 2020 12:27:56
by Mikej
:mrgreen: :mrgreen: :mrgreen:
Posted: Sun 26. Jan 2020 14:54:42
by Mikej
Do you think that I need to worry about my 83,932,936% vibes - bad blade tracking perhaps?? :geek: :geek:
