Telemetry problems
Posted: Sun 22. Mar 2020 17:43:50
by shoveopoly
Hi all. New guy in need of a little help. I have a Spirit Pro and Hobbywing 60a platinum V4 hooked to a RXSR receiver sending telemetry to my Taranis X9D. I get all sensors showing up, but RB1V shows 0. Well aware RB1A and RB1C will stay at 0, because 60a doesn't have the output for it. Thanks for reading.
Re: Telemetry problems
Posted: Sun 22. Mar 2020 20:51:33
do you see at least some value from hobbywing telemetry?
For example RPM?
If not, then problem is possibly in the old HobbyWing ESC firmware.
Posted: Sun 22. Mar 2020 21:52:18
by shoveopoly
I see RPM, FUEL, tmp1, 5120, and RB2C. RB1A and RB1C are zero, as expected with the 60a. Just not sure why RB1V is also zero. Might it be because only bench testing with no blades?
Posted: Wed 25. Mar 2020 19:37:36
you should really see RB1V value from the beginning.
Maybe your motor is disconnected. This would explain the problem.
