I updated to 2.8.0 and enabled the governor.
The heli was flying fine on 2.7.1.
After the 1st time I replaced the servo arms that snapped (designed to do that), and did a full head setup. Everything was level. Setup was correct.
Started spoolup and after 4-5 seconds it suddenly rips to the right.
Repaired it, re-did swash levelling etc and tried again. Exact same thing. Rolls to the right.
3 times now. I cant get off the ground.
Heli was initialised on a flat level surface.
What's causing this?
Tip over on spoolup
unfortunately it look like you have possibly plugged servo connectors incorrectly - CH1 to CH3, CH3 to CH1 or servo reverses are incorrect.
Alternatively Position or Swashplate type.
Before spoolup swashplate should be level, so moving with sticks is not good idea - this could cause tip over if you are moving with sticks during spoolup.
