How to plug hobbywing 200 into spirit
Posted: Tue 16. Jun 2020 8:58:59
by Heliupman567
How do I plug my hobbywing 200 ESC into the spirit 2 for telemetry.. picture is the cables from the ESC. And I have a Jeti Rx plugged into the spirit.
Sent from my Redmi Note 7 using Tapatalk
Re: How to plug hobbywing 200 into spirit
Posted: Tue 16. Jun 2020 11:49:37
by yufasa
Move that yellow wire to the middle position of the connector and then plug it into the “Ele/Pit/Ail” port on the Spirit 2
The Brown/Red wire can be plugged into Aux2 as a Power supply (BEC) but is not needed if you use Aux1 as the throttle, unless of course you left your throttle on your receiver then you do need to connect it.
Posted: Tue 16. Jun 2020 18:47:26
by Heliupman567
yufasa wrote:Move that yellow wire to the middle position of the connector and then plug it into the “Ele/Pit/Ail” port on the Spirit 2
The yellow wire is rpm out.. I'm trying to get mah consumed.. so I can fly of the mah and not a timer..
Posted: Tue 16. Jun 2020 19:01:56
by andy6409
Posted: Tue 16. Jun 2020 19:14:24
by urgno
Posted: Tue 16. Jun 2020 21:23:41
by Heliupman567
Yes I have it all working now, using the cable from spirit plugged into the programming port on the ESC.. so the cables I showed in my pictures are just not needed on the ESC. I have just cable tied them all up under the Heli.
Thanks for you help.
Posted: Tue 16. Jun 2020 22:59:24
by urgno
well, the second bec cable can be helpful if you have demanding servos
so is better to connect it to any free spirit connector (
NOT sys or ele/pit/ail)
dont know the size of that heli, but 200A esc, for sure is not a 450
