Kontronik TelMe settings in ESC
buttles
I have searched, promise! Just need to confirm the progunit settings in the Kosmik and Jive Pro.... Is it Motor Poles 2 and ratio of 1.0:1?
I know the Spirit needs the correct details entered. Thanks
yes. This is default settings and should work well.
buttles
Thanks Tomas, thought so!!
azaz44
Just wondering, why not set it properly? In Kosmik you will then get the right RPM in the log files.
buttles
'Cos in Jeti Data Analyser you get the same
Telemetry will work properly as well
buttles
Is there a reason the Spirit Telme to Jeti doesn't include BEC voltage from Kontronik ESCs? It's rather an important bit?!! Back to jLog otherwise...
buttles
azaz44 wrote:Just wondering, why not set it properly? In Kosmik you will then get the right RPM in the log files.
Kontronik Device Explorer has entries for divider and pole count so basic info into it can be shown correctly
azaz44
Ok, that makes sense. This removes the need to reconfigure the Kontronik when you change gearing.
I didn't notice that in Kontronik data explorer, but will check next time I use it.
