Kontronik TelMe settings in ESC
Posted: Fri 26. Jun 2020 13:06:33
by buttles
I have searched, promise! Just need to confirm the progunit settings in the Kosmik and Jive Pro.... Is it Motor Poles 2 and ratio of 1.0:1?
I know the Spirit needs the correct details entered. Thanks
Re: Kontronik TelMe settings in ESC
Posted: Fri 26. Jun 2020 13:41:01
yes. This is default settings and should work well.
Posted: Fri 26. Jun 2020 15:13:26
by buttles
Thanks Tomas, thought so!!
Posted: Fri 26. Jun 2020 17:58:51
by azaz44
Just wondering, why not set it properly? In Kosmik you will then get the right RPM in the log files.
Posted: Fri 26. Jun 2020 22:02:28
by buttles
'Cos in Jeti Data Analyser you get the same
Telemetry will work properly as well
Posted: Tue 30. Jun 2020 15:48:28
by buttles
Is there a reason the Spirit Telme to Jeti doesn't include BEC voltage from Kontronik ESCs? It's rather an important bit?!! Back to jLog otherwise...
Posted: Wed 01. Jul 2020 19:56:30
by buttles
azaz44 wrote:Just wondering, why not set it properly? In Kosmik you will then get the right RPM in the log files.
Kontronik Device Explorer has entries for divider and pole count so basic info into it can be shown correctly
Posted: Thu 02. Jul 2020 13:28:51
by azaz44
Ok, that makes sense. This removes the need to reconfigure the Kontronik when you change gearing.
I didn't notice that in Kontronik data explorer, but will check next time I use it.
