Setup limits - on the Spirit or on the Tx?
alex4orly
I am new here and need to learn to hover first.
I want to set my Pitch range to : -5, 0, +8
Can I do that somehow on the Spirit Limit tab or only on my Tx?
Thanks for any guidance
Yesterday is history, Today is a present, Tomorrow... a dream.
urgno
you can do that in both places
but in my opinion is better to set the maximum pitch available on spirit ( +-10 / 12° depends on your mechanic )
then you setup the pitch curves in your TX so you can choose with a switch what curve to use
xoexoe
I believe that setting is on the Limits tab.
I agree with the post above. If you’re a beginner then do something like –10 deg / +10 deg, or –12 deg / + 12 deg. I’ve been flying 2 years and 12 degrees is plenty for me.
Use pitch curves in your TX to then get the actual desired pitch range.
Find me on HeliFreak, username Xoexoe
alex4orly
urgno wrote:you can do that in both places
Yes, that is how I did it
