Question about additional SRXL2 Satellites...
Posted: Thu 15. Oct 2020 15:58:07
by Mattes61
Hello together,
I have an question about the possibility to have additional srxl2-satelllites at the satellite ports of the FBL, like described in the new firmware 3.20, look at the screenshot - Can I buy an adapter cable in the shop ? Please can you describe how that should be possible.
Thanks a lot in advance !
Best Regards
Matthias
Re: Question about additional SRXL2 Satellites...
Posted: Fri 16. Oct 2020 20:55:41
by Mattes61
Hello Tomáš,
Have I something misunderstood ? Can I attach the normal DSMX-Satellites at the Sat-ports or can I really attach an additional SRXL2-satellite at the sat ports but how ?
I see in the Shop no adeqate cable to attach for example from sat port 1 or 2 to an SRXL2-satellite -
Please can you give me for clarifcation an answer, maybe I understand this here not right ?
Thanks !
BR Matthias
Posted: Fri 16. Oct 2020 21:05:41
you can connect SRXL2 satellites at the SAT ports. We will make available the cable, hopefully on monday.
So for example you can connect up to 3x SPM4651T satellites.
Posted: Fri 16. Oct 2020 21:51:52
by Mattes61
Hello Tomáš,
thanks a lot for your fast response and great support !
BR Matthias
Posted: Sat 31. Oct 2020 21:47:17
by Mattes61
Hello Tomáš,
sorry I know that you are very busy but I want to ask when the new SRXL2-cable (for more than one satellite) will be available in the shop ?
By the way is it then possible to mix different satellites as SPM4651T and SPM9747 (both are Spektrum)
Thanks a lot for your answer !
BR Matthias
