Rudder ESC - range (tunning)
Posted: Mon 19. Oct 2020 17:41:24
by daniel_i
I fail to understand how this tab should be setup Rudder ESC - range (tunning)
What I do:
1. Existing values from the manual
1. I tick the checkbox
2. motor starts idle at low speed
3. once I click any slider motor starts spinning at full speed.
4. at this point already have less than 5 seconds to act since this can burn the motor/esc
5. I quickly move the left side slider to get any feedback from the motor
6. from multiple tries I figured out that motor stops at ~200 value.
7. any other value does no change - motor spins at full speed
Can I get some hints if this works correctly or do I miss some steps?
Re: Rudder ESC - range (tunning)
Posted: Tue 20. Oct 2020 7:36:28
the process seems to be good.
At step 7. you should start from the lowest value. If it will still spin up quickly, then please set the lowest value.
