SAB Kraken 580 Setup
TWheli
i share my Setup for the new SAB Kraken 580 maybe it is helpful to someone
Setup:
Spirit RS
Swash 3xGDW BLS590 - 17mm
Tail 1x GDW BLS895 - 18mm
Xnova 4025-560
Jive Pro 120
12s 3300
SAB 570 TB
SAB 95 TB
i work nice with the stock blades or MS Rapid 580 blades between 1800 and 2400 rpm
Best Regards
Timo
Kraken580.4ds
(255 Bytes) Downloaded 491 times
TWheli
some pictures
Luv2fly2
Where did you get that antenna holder?
TWheli
Included with the Kraken kit
Goody63
Hi there
Just wondering if you had any issues getting the cyclic range centred (e.g. 12+ to 12-).
I have the same setup (GDW servos etc) but only seem to be able to get a equal range of travel by winding out the Blade Grip linkage rods a fair way (and starting to worry how much thread they have to be secure).
When I wind the Servo linkages out a touch to compensate (and reduce the length of the blade grip linkages) then I cant seem to be able to get a even cyclic range (ie end up with something like 10+ to 13-).
Any help would be much appreciated.
Cheers
