Which swashplatetype
Diamondblack
I have an jetcat pht3 turbine with 4 servos on swashplate. The problem is that the spirit pro can only H4 90deg i need H4 90deg +45deg.
No it is a hc3sx mounted on the turbine but i would like to fly with the spirit.
So what can i do?
Is it possible to get an update in the future where this will work?
tomsl
Hello
what you are looking for is on the EXPERT SETTINGS page.
Cyclic phase:
The value indicates the angle by which the swashplate is virtually rotated. For example a value of 90 will rotate the elevator to aileron. This feature is recommended for models with multi-blade rotor heads. For most other models, we recommend a zero value.
official hacker distributor USA
www.hackermotors.us
Diamondblack
Have try this to change to minus and plus 45 but it will not work
for sure it can work with Phase angle rotation. We have many scale pilots with similar helicopters.
If not +45° then -45° can work. Then only correct servo reversing is needed.
Diamondblack
okay will try again. Can you say me how i have to plug in the servos then?
Servo ch number on spirit
front left ?
front right ?
rear left ?
rear right ?
that will be great!
