[SOLVED] Spirit 2 and Jeti DS16
nzlsubzero
Hi
I am trying to get AUX1 working for the throttle. I have assigned the 'Throttle' in the setup to Channel 1. This should have the throttle output now on AUX1 output from the unit. The ESC however will not initialise. If i however use an RX output to the ESC, I can get the ESC to work. I would prefer to use AUX1.
Any suggestions will be very helpful.
it is enough to recalibrate the ESC, because it has throttle range from the receiver.
Or you can change settings in the Spirit unit in the General - Throttle - Throttle Range so it will match the old range from receiver.
Range from receiver is 1000 - 2000us. So after changing everything should work.
nzlsubzero
Hi ZeXx86
:D :lol:
That worked. Excellent.
Thanks for the prompt response. Much appreciated.
Cheers
