[SOLVED] Spirit GT 2 questions
HeliMLM
i am asking myself 2 questions in preparation of replacing a Spirit 2 by a Spirit GT in my Diabolo 700:
1. the auto rescue feature: the height is defined in meters from: a. Spirit GT initialisation point (in my case: prep.bench (~2-3m higher than starting point) or from b. (motor) starting point / takeoff point?
2. the (great!) new logging: is there a way to test it on bench without RPM signal? logging will not start unless RPM signal is showing "motor running"? (i'd like to play around a bit and configure new telemetry features like max. height alarm and maybe max. speed alarm before switching to GT unit.)
thx a lot
Michael
cheers
Michael
1. always calculated from take off position
2. RPM signal is not needed. Logging is started when there is a certain level of vibration, which is not present when nothing is rotating.
So you will normally not trigger logging by mistake even during model manipulation.
HeliMLM
Hello Tomas,
thx for the explanations... perfect with the take-off-position!
cheers
Michael
