Swash plate reset speed and setting software problems
Posted: Sat 09. Oct 2021 17:23:49
Hello
There are 2 doubtful questions recently:
1: CCPM swash plate state recovery speed problem: the remote control moves the joystick, and after releasing it, the swash plate resets quite slowly. I tried the following tests and produced different reset speeds.
a: BEC power supply: If the gyro is far away from the electronic governor, it will increase the speed of the swash plate to reset. If it is too close, it may not reset occasionally. (BEC output line of ESC and anti-interference magnetic ring installed)
b: Battery power supply: 2S lithium battery power supply, the swash plate reset speed is very fast
c: Touch the top with your hand: Touch the aluminum shell of the top with your hand, and the swash plate will return very quickly.
Thinking =
ESC electromagnetic interference and possible electrostatic interference? ? ?
2: Setup software flash crash problem
Recently, it was discovered that after the gyro software on the PC (WINDOWS 10) was started, the software interface disappeared after more than 10 seconds (understood as a software crash?) (including laptops and desktop PCs). Before using the RS and S2 gyro, the previous version of the software, this has not happened.
Thinking =
Caused by the latest version?
Thank u
Thinking =
Thinking =
Thank u
